Custom Orientation Per Sprite after applying Sprite Wizard
COW Forums : Autodesk Maya
twiggles
on Mar 3, 2007 at 9:15:52 pm
Hi everyone...
I've got a problem I hope someone could help me with. I've created an emmiter and plugged in random images on sprites using the sprites wizard. Everything is fine until I try creating a custom orientation/radius per sprite (runtime expression) The Sprite wizard has added a script to it and I can't seem to add/modify/create a custom expression for it. Anyone had this problem before?
Andrew
