Maya in Vista64 ?
COW Forums : Autodesk Maya
frank weber
Maya in Vista64 ?
on Feb 28, 2007 at 3:43:35 pm
Hi. Does anyone know how maya behaves in Windows Vista(64 or 32)?
Should I get Vista-64 or 32?
The Answer is 42.
Chad Briggs
Re: Maya in Vista64 ?
on Feb 28, 2007 at 11:38:30 pm
I haven't personally tried it, but i'm willing to bet you'd be better off staying with xp pro 64. Vista isn't going to make maya run any better, and most likely will slow it down unless you turn off all the areo stuff.
-chad
frank weber
on Mar 1, 2007 at 9:42:31 am
How lame is that?
...Thanks.
The Answer is 42.
Chad Briggs
on Mar 1, 2007 at 4:12:25 pm
It's part of the process. Supposedly the technologies that MS introduced are quite cool, but it requires developers to re-code the apps to take advantage of it, which takes a while. Part of the breaks of the software lifecycle.
-chad
