make wire frame tubular geometry?
COW Forums : Autodesk Maya
jim
by
on Feb 22, 2007 at 10:45:51 am
is it posible to convert a wire frame into a renderable skeleton of itself?
i.e you look at a sphere in wire frame and apply geomety to the wireframe so you can control the thickness and shaders on those lines and render them out?
cheers
jim
Steve Sayer
Re: make wire frame tubular geometry?
on Feb 22, 2007 at 2:25:37 pm
You could use the vector renderer, or Paint Effects, or you could actually create geometry by extruding a NURBS circle along each isoparm or edge. I think there's a plugin or script that automates that--do a search on HighEnd3D.
-Steve
