3D Text
COW Forums : Autodesk Maya
Side FX
3D Text
on Feb 19, 2007 at 7:00:34 am
Ok. So I imported my Illustrator text into Maya witht the idea that I could then extrude
surfaces or otherwise convert it to a 3D Model.However, I can't seem to find the command
to convert the raw text into anything useable. Any ideas?
Thanks.
Steve Sayer
Re: 3D Text
on Feb 20, 2007 at 6:41:04 am
What version are you using? If there's a tool called 'BevelPlus' that's probably your best bet.
-Steve
Side FX
Re: 3D Text
on Feb 21, 2007 at 8:18:59 am
I solved it by just creatting as polys and extrudinging the surfaces out.
