Dynamics of Instance Geometry in a particle system...
COW Forums : Autodesk Maya
Christof van Niekerk
on Feb 14, 2007 at 10:45:25 am
I'm trying to animate coins falling down onto a hard surface.
I'm using a particle system referencing the geometry of a modelled coin.
These particles are affected by a gravity field that makes them collide with a plane. (passive rigid body)
My problem is that these dynamic collisions & reactions are not taking the shape of the instanced geometry into account. (They all bounce & retain the same orientation.)
Please advise on how I can get these particles to react dynamically according to the referenced geometry's shape....
Steve Sayer
Re: Dynamics of Instance Geometry in a particle system...
on Feb 14, 2007 at 5:05:38 pm
This cannot be done with particles. The purpose of instancing geometry to particles is to simplify the calculations needed, treating each object as a simple point object for the purposes of forces and collisions. You will need to duplicate the coins and make each duplicate a rigid body.
on Feb 15, 2007 at 4:28:41 am
OK. I was hoping it wouldn't come to the solution you suggested...
But at least I now have closure on what the technique can & can't do.
Thanks for the help Steve.
