converting file from Maya8.5 to Max9 for "Mentalray" render(Gaming)
COW Forums : Autodesk Maya
ramesh03
on Feb 6, 2007 at 2:37:51 pm
We done everything in maya8.5(Modeling,Animation,Texturing,Rigging etc..) after that we want to convert that to max9 by using the fbx-plugin.After convertion we saw output in max9 some problems with Animation(some jurks) and Texturing(uvs problem). Any special plugins are there for that.
Is it possible to get everything in max, what i done in maya.
I want to know one thing, for Mentalray which gives better quality & efficiency(Max or Maya) for Gaming.
I am waiting for ur reply.
Sean Fennell
Re: converting file from Maya8.5 to Max9 for "Mentalray" render(Gaming)
on Feb 6, 2007 at 9:44:26 pm
Max and Maya use the same version of the mental ray rendering engine, so I imagine you would get the exact same output from both. Just the interface to the renderer is slightly different. And the organization of all the settings is different. I really can't think of a reason to go from maya to max if your only reason is to render in mental ray.
For maya, select window->Settings and Preferences->Plug-in manager and check 'load' next to MayaToMr
