Unhiding channels
COW Forums : Autodesk Maya
Wagster
Unhiding channels
on Feb 1, 2007 at 5:28:20 pm
After you've locked and hidden a channel in the channel box... how do you get it back?
New York-based Editor-Compositor
teerav
Re: Unhiding channels
on Feb 1, 2007 at 5:34:04 pm
you cant...naaa you can. in the Channel control window.
Pyro
by
on Feb 1, 2007 at 9:29:39 pm
Set the "Visibility" parameter in the channel box to 1 and the camera shape should then be visible. You can also use Display>Show>Show All but this will make all your cameras visible, including orthographic cameras.
Hope this helps.
Wagster
on Feb 2, 2007 at 3:54:06 pm
Got it, thanks.
