Mirrorball modeling
COW Forums : Autodesk Maya
Mirrorball modeling
on Jan 31, 2007 at 11:02:00 am
Hi, I'm looking for some advice on the best process to model a mirrorball (the club kind NOT HDRI).
I'm pretty new to Maya modeling and wondered if the look could be achieved by simply applying a shader/texture to a sphere primitive? or do I need to create an polar-array of the actual mirror titles?
I guess my aim is to offset image quality against render time (as always ;))
Thanks in advance for any advice
Chad Briggs
Re: Mirrorball modeling
on Jan 31, 2007 at 10:55:07 pm
The easiest way to do this probably is just create a polygon sphere with the number of faces you like, bevel it, then turn off normal smoothing.
voila, then all you ahve to do is assign the relfective shader. If you want the little white lines like in the pix, you'll have to select the beveled edge, and apply the white shader to those faces.
hope that helps
© 2018 All Rights Reserved
