Maya vs Lightwave
COW Forums : Autodesk Maya
Maya vs Lightwave
on Jan 29, 2007 at 6:47:33 pm
I have clients who could use simple (but realistic) animations of their routers - just spinning and stopping. I need an artist who can help with this. Should I look for a lightwave person or a Maya person.
And, should I try and get existing models from the company to be imported into the software that the artist then can animate?
Thanks for the guidance
Steve Sayer
Re: Maya vs Lightwave
on Jan 29, 2007 at 7:47:23 pm
Hi, mmromo.
I will say that you should look for a Maya person, simply because I am a Maya person and would be willing to take the job. :) That being said, I'm sure Lightwave would be more than capable of producing the same results.
If 3D models of the products already exist, that will save your artist quite a bit of work, so you should definitely see if you can get them. Failing that the routers will have to be modelled from scratch, in which case a few good photos, including flat views from all angles, will be very helpful.
If you wish to discuss details and get a quote, you can email me at steve at stephensayer--I'm trying to defeat the email harvesting bots here--dot com.
© 2018 All Rights Reserved
