Diamond shape with a MAYA ramp
COW Forums : Autodesk Maya
accpph
on Jan 26, 2007 at 9:07:09 pm
Hey,
I'm trying to force a ramp to create a diamond shape like this http://www.rit.edu/~accpph/images/cg/diamond_01.jpg . Of course I can get a box and rotate it 45 degrees. But I want to pinch two corners like in teh web link above. I get close with a sleight V wave value, but it's not perfect. Can I use a ramp. or many ramps to get a shape like the one in the web link, if yes, how?
Thanks.
ACC
Steve Sayer
Re: Diamond shape with a MAYA ramp
on Jan 27, 2007 at 8:09:48 pm
Is there some reason you don't want to use a file texture?
Try the following settings with a Box Ramp or a Grid texture:
Rotate UV 45
Repeat UV 3, 1
Then set Rotate Frame to taste.
-Steve
accpph
on Jan 28, 2007 at 2:55:16 am
Hi:
Yeah my reason is control. Folks over at bluesky only use procedurals and I kinda wanted to see how far I could push it.
ACC
