MMB problem
COW Forums : Autodesk Maya
barry3232
MMB problem
on Jan 20, 2007 at 11:48:39 pm
Hello, for some reason my middle mouse button doesnt function in Maya 8...does anyone have any tips on how to fix this.....Thanks for any info...
markyyyy
Re: MMB problem
on Jan 21, 2007 at 1:16:01 pm
did you check in you preferences... under interface-device, you can choose between 1,2 or 3 button mouse (choose 3)..
if it is selected, than check under you system preferences... if you have the mighty mouse and have installed the software, you can set the scroll wheel to be button #3.
good luck,
Markyyy
-stev=o
Re: MMB problem
on Jan 25, 2007 at 8:35:38 pm
Many factors could go into this.
Do you have the latest mouse drivers installed? Sometimes the mouse drivers are incompatable. You might have to try uninstalling them.
Also, make sure that if you have a Nvidia card that you're not using and special middle mouse features in the Nview properties.
-stev=o
