Texturing question
COW Forums : Autodesk Maya
JamesPorter
Texturing question
on Jan 10, 2007 at 8:14:02 pm
Can you texture a character after you've rigged, painted weights and even sorted out the blend shapes?
The character's aren't going to have complexed textures, probably a very simple shading network.
I didn't want to make my characters and then start again because they weren't textured.
Many thanks
James
Steve Sayer
Re: Texturing question
on Jan 10, 2007 at 9:08:14 pm
Yes, texturing can be done or re-done at any stage. Good luck!
-Steve
teerav
on Feb 1, 2007 at 5:51:01 pm
definetly, i prefer to texture after i have done all my rigging. sometimes during the rigging process youll find that you need to rework the mesh a bit in order to get the correct deformation your looking for. if you've already laid out your UV's and textured everything, youll most likely have to redo it.
