repeating frames question
COW Forums : Autodesk Maya
Teasider
on Jan 9, 2007 at 12:30:14 pm
Hey
Im doing a jumping ball in place. which have the same jumpingsquashing frames. I want that to repeat while I rotate the camera around and over.
is there a way to duplicate the jumping ball's frame? or any other method for that matter so I could animate the camera around the repeating frames?
thanks in advance!
Steve Sayer
Re: repeating frames question
on Jan 9, 2007 at 6:01:58 pm
Sure. If the ball ends in the same place it begins, just go into the Graph Editor and set its animation curves to loop.
Select the curves and right-click. The option is in there somewhere, I forget where... you want 'Repeat' but probably NOT 'Repeat with offset'.
-Steve
