rendering w/ wireframe?
COW Forums : Autodesk Maya
joe
by
on Jan 4, 2007 at 9:33:52 pm
Is there a way to render with the object textured and shaded, while also having it render the wire frame?
Andrew Shau Seong Yap
Re: rendering w/ wireframe?
on Jan 5, 2007 at 9:44:58 am
What you could do is render your textured and shaded objects as you normally would and then render the same sequence again via hardaware render (window>rendering editors>hardware render buffer>render>render modes>draw style>wireframe). You could then composite the rendered wireframe over the shaded objects within a compositing sofware like after effects.
hope that helps
Andrew
joe
by
on Jan 6, 2007 at 12:14:17 am
cool thanks
