fading bump map
COW Forums : Autodesk Maya
markyyyy
fading bump map
on Dec 30, 2006 at 7:23:50 am
I've created a cylinder with a bump map on it... I would like the bumps to be full at the top of the cylinder and faded out at the bottom... How do I get to do that... I tried putting a gradient map on the value node of the 2dbump, but it doesn't work...
any ideas?
thanks,
markyyy
markyyyy
Re: fading bump map
on Dec 30, 2006 at 1:00:30 pm
Got it! it was just a question of playing with the projection type (U,V etc)
markyyy
accpph
Re: fading bump map
on Jan 1, 2007 at 1:53:24 am
Hey,
I realize you've answered this already, but you could take your bump map and run it into one channel on a ramp whose values go from bump to medium gray. That should let you control the fall off
ACC
