render problems
COW Forums : Autodesk Maya
markyyyy
render problems
on Dec 28, 2006 at 4:28:42 pm
I'm trying to render a simple 90 frames animation... The only "animated" object is the camera. when I go to render, it says that render has started, 10 seconds later or so it says that render is completed (I thought I had a super fast machine :) ) but unfortunately, nothing was rendered... there is no error message, everything seems OK... and yes I've set the preferences in maya render to multiple frames and not single frame....
thanks,
Markyyy
mYthprod
Re: render problems
on Dec 28, 2006 at 8:05:00 pm
Check to make sure the camera you want rendered is the one that's actually rendering - in the AE check that the desired camera's "render" checkbox is checked. Also make sure your render globals have the proper range entered.
- MythProd
(John David Hutton)
_________________________________________
Digital Effects Artist, Support Technician
Kansas City, Kansas - United States
markyyyy
Re: render problems
on Dec 29, 2006 at 9:24:26 pm
OK, I got it to work... I thought the only way to render an animation was through batch render, but I got it to work using the simple render option.
thanks,
Markyyy
