Maya issues, need help
COW Forums : Autodesk Maya
saeed faridzadeh
on Dec 22, 2006 at 11:13:51 pm
I'm working on a box with Maya 8, and the new form of creating objects like 3dsMax is throwing me off a little. Is there a setting to have it go back to the old way, of creating an object and have it show up by default on 0,0,0.
At least until i get used to this new way.
2nd. Weird issue. When I hit the spacebar to bring up the menu, it'll bring up the menu, then quickly also go into the 4 panel view while the menu is still up. Very annoying. However the wacom intuous 3 has one of the buttons set to spacebar (for combustion) and when I hit that, the menu bar stays up the way it's suppose to, and the view doesn't switch over into the 4 view plane.
Any ideas? Just minor annoyances. But they bug me enough to hinder my work.
Sean Fennell
Re: Maya issues, need help
on Dec 23, 2006 at 7:48:04 am
with regard to the first question:
from What's New->General in the manual
Options can be set for single-click and click-drag polygon creation, using the Polygon Tool settings (Create > Polygon Primitives > Shape > []options box)
© 2018 All Rights Reserved
