Rendering a shadow pass
COW Forums : Autodesk Maya
cow
SSGGMM
on Dec 19, 2006 at 1:59:45 am
Hello,
I read that the simplest way to do a shadow pass in mental ray is to turn off "primary visibility" in the object's render stats, while leaving "cast shadows" on. Works fine, but what if you have dozens of objects littering your scene? Do you really have to turn off visibility forty-eight times? Isn't there an easier way, say, in the render globals? Any ideas?
Thanks - Serge
Steve Sayer
Re: Rendering a shadow pass
on Dec 19, 2006 at 4:14:38 pm
Select all the objects, then use the Attribute Spreadsheet. There should be a 'Rendering' tab, and you can highlight the entire column for 'Primary Visibility' and turn them all off at once.
-Steve
SSGGMM
on Dec 20, 2006 at 5:44:21 am
Perfect. That solved it nicely. Thank you.
S.
Rohit Rajan
on Sep 6, 2012 at 5:59:12 am
select all object.go to attribute spread sheet and turn off the primary visibility.windows>general editors>attribute spread sheet.(maya 2011)
