concave monogram
COW Forums : Autodesk Maya
jim
concave monogram
by
on Dec 15, 2006 at 12:37:20 pm
Hi cow polk,
I need to press a letter into a subdiv chocolate and can't seem to get a high quality result.
I tried converting to poly's and then doing a bolean intersect which did the job.
However when I went back to sub div it looks rubish?
are there any other methods.
cheers
Jim
Steve Sayer
Re: concave monogram
on Dec 17, 2006 at 6:45:45 pm
What do you mean "it looks rubbish"?
Did you try creasing the edges of the holes after converting back to SubD?
-Steve
jim
by
on Dec 18, 2006 at 10:47:26 am
http://www.style45.co.uk/cow/Pic1.jpg
heres the looking rubish example and here's the reason why I can't select the edge.(too many edges)
I am hoping it's something easy or a different approach thats needed.
cheers for your help past and future.
Jim
learning on the Job:)
jim
by
on Dec 18, 2006 at 11:37:11 am
I have decided to bump map to get the job moving.
but I would still be into hearing solutions for this problem, I'm sure there will be times when a bump just wont do.
thanks again
Jim
jim
by
on Dec 18, 2006 at 4:30:20 pm
howdy cow polk,
forget that bump map nonsense!
incase any one finds them self in the same situation I was in I will tell you my solution.
use a displacement map with a multiply divide node to press in my monogram then convert displacement to poly.
the result is a bit heavy on the poly count but the result is broadcast smooth and render times are bearable.
cheers
Jim
Steve Sayer
on Dec 18, 2006 at 5:09:21 pm
...I was just going to suggest displacement instead of bump. :)
I agree that the SubD version didn't really look very promising--the geometry wasn't flowing well at all. Not sure if there might have been a fix for that--I'm not really a modelling guy.
Sorry I took too long getting back. Hope the project works out.
-Steve
jim
by
on Dec 18, 2006 at 5:17:40 pm
"I agree that the SubD version didn't really look very promising--the geometry wasn't flowing well at all"
yeah booleans may be quick but they sure are dirty.
cheers
Jim
