How do i keep my single-frame persp. renders the same angle and size in different projects?
COW Forums : Autodesk Maya
billyvoltron
on Dec 6, 2006 at 2:18:01 pm
Is there an easy way to keep my renderings (in perspective view) on different t projects the same??? Like the same dimensions, same persspective, same size etc.?? I am doing single-frame renderings of floor plans that i have created and want them to be all from the same perspective and same size. Thanks
Steve Sayer
Re: How do i keep my single-frame persp. renders the same angle and size in different projects?
on Dec 6, 2006 at 4:07:21 pm
Hi. You could create a bookmark for the camera view in one scene, then select the camera and export it to a new file. You might need to check some of the 'Include these inputs' options to get the bookmark to go with it, I'm not sure.
Then just import that camera into your other scenes and set it to be the rendered cam.
-Steve
