> Maya 8 Spotlight Error With Mental Ray
COW Forums : Autodesk Maya
gybp
by
on Nov 25, 2006 at 2:15:08 pm
any time i create a spotlight in mental ray and select it i get this message:
select -r spotLight1 ;
// Error: The mentalrayLightexponentCtrl control cannot be used with the attribute "spotLightShape1.exponent". The attribute type is not compatible with the control type. //
// Error: The mentalrayLightcausticPhotonsCtrl control cannot be used with the attribute "spotLightShape1.causticPhotons". The attribute type is not compatible with the control type. //
// Error: The mentalrayLightglobIllPhotonsCtrl control cannot be used with the attribute "spotLightShape1.globIllPhotons". The attribute type is not compatible with the control type. //
// Error: The mentalrayLightsmapResolutionCtrl control cannot be used with the attribute "spotLightShape1.smapResolution". The attribute type is not compatible with the control type. //
// Error: The mentalrayLightsmapSamplesCtrl control cannot be used with the attribute "spotLightShape1.smapSamples". The attribute type is not compatible with the control type. //
// Error: The mentalrayLightsmapSoftnessCtrl control cannot be used with the attribute "spotLightShape1.smapSoftness". The attribute type is not compatible with the control type. //
// Error: The mentalrayLightsmapBiasCtrl control cannot be used with the attribute "spotLightShape1.smapBias". The attribute type is not compatible with the control type. //
// Error: The mentalrayLightsmapDetailSamplesCtrl control cannot be used with the attribute "spotLightShape1.smapDetailSamples". The attribute type is not compatible with the control type. //
// Error: The mentalrayLightsmapDetailAccuracyCtrl control cannot be used with the attribute "spotLightShape1.smapDetailAccuracy". The attribute type is not compatible with the control type. //
and the light dont work ok with caustics and FG. whats the problem?
