Deform object to surface
COW Forums : Autodesk Maya
Levels
on Nov 22, 2006 at 5:33:08 pm
Is there a way too deform an object to a surface and animate it? For example say you have a nurbs plane modeled as a landscape with little hills and you want the object (nurbs sphere), say a mole, to deform a long that surface evenly....
T
Steve Sayer
Re: Deform object to surface
on Nov 22, 2006 at 7:45:15 pm
I think the Sculpt Deformer is exactly what you're looking for--look into it. Also check out other deformers, like Wrap and maybe Wire.
If you want the mole to leave a raised trail behind him, you might look into an animated displacement map instead.
Another solution might involve making your ground a softbody, and using Dynamics to create the animated effect.
Lots of possibilities!
Good luck,
-Steve
Levels
on Nov 22, 2006 at 8:41:53 pm
Thanks Steve. Let the tests begin!
T
