Possible to render just a mask pass?
COW Forums : Autodesk Maya
Steve Sayer
on Oct 20, 2006 at 10:25:21 pm
Alright all you rendering and compositing gurus, tell it to me straight--are Maya's 'render RGB channels' controls mere placebos?
You can check and uncheck depth, alpha, AND colour channels in the render globals. This suggest that--in theory--it is possible to render out a single-channel image containing only mask info (or depth info). But I have never--and I mean NEVER--been able to get this to happen. It seems to me that the colour channels are ALWAYS rendered out. Sure, it's easy enough to get them to render out solid black--but is it possible to not include them at ALL? Why quadruple the file size when all I want is a mask pass? (Okay, it's not quadrupled when I use a compressible file format like TIFF... but you get the point.)
And if not... why give us those darned checkboxes?!
-Steve
Steve Sayer
Re: Possible to render just a mask pass?
on Oct 20, 2006 at 10:30:41 pm
I should mention that I've tried fiddling not just with Render Globals, but also with camera attributes, render layers (though I don't have a lot of experience with those), and even flags for the command line render. "render -rgb off -alpha on" produces the same output as "render -rgb on -alpha on".
Any insight appreciated!
-Steve
Jason Brummett
on Oct 24, 2006 at 8:40:42 pm
Try using Render layers preset of Geometry Matte,
This will render out just a matte for you? Is that what your after
Jason Brummett
Studio Z Inc.
Jason Brummett
on Oct 24, 2006 at 8:45:33 pm
Never mind,
That only works for %100 percent opaque geometry :(
Yeah, dumb I agree!
Jason Brummett
Studio Z Inc.
