Layered Texture alpha cuts more than alpha channel
COW Forums : Autodesk Maya
tom custer
on Oct 20, 2006 at 6:58:06 pm
Using Maya 8. Trying to place a lable with layered textures. Used tutorial in Learning Maya 7 as a guide.
When I tried to apply it to my project connecting the projection map alpha to layered texture node it cut out the black and blue colors in the lable. I've tried every format and checked the alpha channel
When I painted the sample in the tutorial file it also cut out the black and the blue but not any other color.
Looked at layered shader but that did not seem to work.
Thanks in advance
