import video clips into maya
COW Forums : Autodesk Maya
Trevor Erickson
on Oct 6, 2006 at 10:36:28 am
Is there a way to bring video clips such as avi files into maya in order to animate them along with other 3d animations. I have Premiere Pro & After Effects. Thanks
Jason Brummett
Re: import video clips into maya
on Oct 6, 2006 at 10:24:05 pm
Yes you can; I would do a search on that topic here as it's been discussed a lot.
Jason Brummett
Studio Z Inc.
zhenka
on Oct 7, 2006 at 12:40:57 am
Also consider rendering out of after effects as an image squence (especially if you are working with alphas) as i had some problems with importing avis, but something like a png sequence worked great for when i was matchmoving my keyed live footage.
jsimpson
on Oct 17, 2006 at 2:31:44 pm
Ayep, your best bet is to convert the AVI to an image sequence.
Keep in mind that you need to use the proper syntax, ie: "bgvideo.bmp.0001" (filename.extension.number) for Maya to be able to keyframe the background sequence.
