simultaneously display the attribute editor and the channel box
COW Forums : Autodesk Maya
evrard
on Sep 25, 2006 at 8:06:39 am
How do i simultaneously display the attribute editor and the channel box?
Steve Sayer
Re: simultaneously display the attribute editor and the channel box
on Sep 25, 2006 at 5:24:13 pm
You have to set the Attribute Editor to display in a separate window (in your Preferences menu). Then you can have them both on screen at once.
-Steve
evrard
on Sep 26, 2006 at 3:31:56 pm
Thanks a lot Steve. I will have one last question if you don't mind: Is it possible to have a different configuration of maya for each project? I mean set differents looks of the interface with personalized menus or shelf so that when i open a project it comes with its tool sets and when i open another project it comes with its own, etc. But still be able to open the software with default configuration whenever needed.
Steve Sayer
on Sep 27, 2006 at 5:55:42 am
You can change your preferences to 'Save Panel Layouts to File' when saving and 'Restore Panel Layouts from File' when opening. That's in the UI Elements section of your Preferences. Beyond that, I'm sure there are advanced ways to configure things, but I don't know off the top of my head, sorry.
I know Maya is incredibly customizable so hopefully someone will chime in with a quick tip if there is one.
-Steve
