Create Modifier Command in Maya 6.5
COW Forums : Autodesk Maya
Jonathan L
on Sep 5, 2006 at 5:03:14 pm
I'm trying to create a modifier in PaintFX for Maya 6.5 to create some turbulence on my PaintFX but I can't find the command. I know it exsists in version 7.0 in the PaintFX menu. Is this something that only came into being with version 7? I have a field of grass that I want to "blow" around as the camera animates through it what are my options?
Jon
Steve Sayer
Re: Create Modifier Command in Maya 6.5
on Sep 6, 2006 at 2:55:07 pm
I don't think you want a modifier for grass wind turbulence; that property should be built into the brush node itself. Select the brush and open Tubes > Behavior > Turbulence in the Attribute Editor.
-Steve
