Use Frame Extension
COW Forums : Autodesk Maya
teakster
Use Frame Extension
on Sep 4, 2006 at 8:21:03 pm
Hi All,
just like to know where to turn on 'Use Frame Extension,' is on the texture node?
Been trying to find this as I want to be able to go from certain points in my image seq/quicktime movie.
Any help would be great!
THANKS
teakster
Re: Use Frame Extension
on Sep 4, 2006 at 8:25:19 pm
Steve Sayer
on Sep 4, 2006 at 11:08:05 pm
Should be in the File node, in the first section 'File Attributes'. It might be called 'Use Image Sequence' instead of 'Use Frame Extension'.
Check the archives for people having problems with QuickTime movies as textures... I think it's generally agreed that image sequences are much less problematic.
-Steve
teakster
on Sep 5, 2006 at 10:04:23 pm
Thanks! Shall try
jim
by
on Nov 30, 2006 at 11:16:35 am
hello I have been messing with this technique for a kids show idea but as this is not normally my line of work am finding it a bit tricky I have made a nice little slider that controls my image sequence to make it al nice an easy to key during animation.
However I can't seem to stop the sequence from running as i scroll the timeline. do i have to do held key frames ie 1 at the start of the hold and one at the end or is there a way to tell maya that the sequense is no only controled by my set driven slider?
I didn't take breath there so I hope you get where I'm coming from.
Cheers for any help
Jim
jim
by
on Nov 30, 2006 at 11:37:39 am
Hello,
I just thumbled my way to answer
if anyone else finds them selves in this situation change the expression node state to "waiting normal"
Cheers
Jim
jim
by
on Nov 30, 2006 at 12:22:53 pm
Update:
I have had better results changing the node state to "has no effect"
