Move Pivot Point
COW Forums : Autodesk Maya
micalclark
Move Pivot Point
on Sep 4, 2006 at 2:17:08 pm
Seems like a pretty basic question, but how do I view and/or move the pivot point for an object? Sometimes I can see the point sometimes I can't and sometimes when I'm moving the pivot point the whole object moves. Thanks,
Mike
SSGGMM
Re: Move Pivot Point
on Sep 4, 2006 at 4:14:17 pm
Hit your insert key.
Also, when you modify an object, its pivot point goes back to 0,0,0 on the grid, by default. (At least, that's my experience.)
Hope I got your question right - Serge
micalclark
on Sep 4, 2006 at 8:22:16 pm
Hi Serge,
Thanks for the quick response. Working on 3 Macs (sometimes a laptop) and there doesn't seem to be an "insert" key on any of my keyboards. It's hung me up a couple of times while doing tutorials.
Steve Sayer
on Sep 4, 2006 at 11:04:40 pm
I think the Mac-Insert question has been addressed before on the forums--try searching the archives.
In the meantime, you should be able to just press and hold 'd' to move the pivot, too... a very handy trick I only learned recently. And of course you can use Maya's hotkey editor to remap the 'edit pivot' toggle to anything you like.
-Steve
Jason Brummett
on Sep 5, 2006 at 9:32:21 pm
yeah the D hotkey is a great one. I find though that I've prefered to use this mel
http://www.3dbe.com/mscripts.html (Pivot Now Script)
Jason Brummett
Studio Z Inc.
micalclark
on Sep 6, 2006 at 1:54:37 am
Thanks guys. I'll try that.
Mike
Glenn Moore
on Sep 7, 2006 at 3:09:13 am
I could be wrong but it seems like you're asking about Center Pivot. It's under the Modify menu item. Select the object and choose that option. The pivot point will be centered so when you rotate, the object rotates around the pivot point instead of some other point.
