how can I take out a number in a string as an integer..????
COW Forums : Autodesk Maya
theodora
on Sep 1, 2006 at 4:12:54 pm
string $A = "crv.cv[15]";
let's say we have a string like the above and we want to take out the number in the string (in this case the number is 15) as an integer variable..Do you know how I can do this??
thanx,
theodora
Steve Sayer
Re: how can I take out a number in a string as an integer..????
on Sep 1, 2006 at 6:45:55 pm
The first step is to isolate the numbers themselves. You can use the 'substring' or 'tokenize' commands to do this.
Once you have a string which contains only numbers, you can set an integer to be equal to it (int $myInt = $myString) and Maya will automatically convert the data to the appropriate type.
-Steve
