Quicktime for bump mapping
COW Forums : Autodesk Maya
Renegade9
on Aug 25, 2006 at 10:57:52 pm
Does anyone know if it's possible to use a .qt file for bump mapping. I have a set up that has a few quicktimes (texture and specular) but the bump seems to have no effect. Any clues?
Chad Briggs
Re: Quicktime for bump mapping
on Aug 27, 2006 at 2:27:36 pm
Your supposed to be able to do this, but my understanding is that it's a bit buggy. I'd export your QT movie to a file sequence and then it should work without any problems.
-chad
Renegade9
on Aug 27, 2006 at 10:28:09 pm
Thanks Chad. I had tried a sequence and that wasn't working. Then after your post I went back checked the file - I hadn't checked that the files were named right and it wasn't reading the sequence. Fixed the naming convention and all is well now!
Thanks again,
jeff.:
