Text & Maya
COW Forums : Autodesk Maya
Side FX
Text & Maya
on Aug 20, 2006 at 8:07:57 pm
Novice question about importing Illustrator files or otherwise creating text in Maya (6.5). When I try to import my Ill CS files, Maya opens FCheck. OK. Now what? How do I get the art/path in the modeling (?) window?
Or are there other/better methods for text and logos and the like?
Thanks.
Steve Sayer
Re: Text & Maya
on Aug 20, 2006 at 9:42:42 pm
Sorry to state the obvious, but make sure you go to the 'Import' command and not the 'Open' command. Beyond that, there may be a version compatibility issue? Try saving your Illustrator file as an older version and see if that works.
-Steve
Mindset
Re: Text & Maya
on Aug 21, 2006 at 6:25:30 pm
can you really import illustrator files and create geometry out of it?
Jon W.
Re: Text & Maya
on Aug 21, 2006 at 8:51:49 pm
Export from Illustrator as eps (at version 8), import curves, Bevel Plus
Side FX
Re: Text & Maya
on Sep 19, 2006 at 6:45:18 pm
Or - I could just go Create > Text > (options), doye. However, the problem here is that the text comes in as an outline and not as a solid.
How to fix?
