how would you uvmap this polygon object?
COW Forums : Autodesk Maya
William Hamilton
on Aug 17, 2006 at 11:54:45 pm
does anyone have any tips or suggestions on how I could go about uvmapping this piece of geometry? I've tried several different ways but have had absolutely no luck with it. Right now I'm trying to figure out a way to do a planer projection from the sides/front/top but am worried that each time I make a selection on the faces I want to project, they may overlap other faces on previous projections. If anyone has any suggestions on how to map this I would love to hear them. Thanks again!
http://www.geocities.com/bannysvideo/mayawoes/batmmesh.jpg
Chad Briggs
Re: how would you uvmap this polygon object?
on Aug 18, 2006 at 1:52:15 am
It's gonna be a pain any way you slice it (pun intended). Check out these tho:
http://www.digidim.info/index2.htm
http://www.highend3d.com/maya/downloads/mel_scripts/texturing/download-3869...
hope that helps
chad
Jason Brummett
on Aug 18, 2006 at 10:55:01 pm
As Chad mentioned. Pelt UVW mapping works great for organic surfaces! I use it quite a bit for charachters etc.
But thought I'd mention you can use the unwrap tools in Maya 7 to great success. Tip is that you need to select the faces you decide should be part of 1 UV shell, hide them and continue around your car until they are all spoken for as selection sets. Then with a little trial and error you can unwrap it! Use your selection sets though...
Good luck,
Jason Brummett
Studio Z Inc.
