How to Connect Node to Image File?
COW Forums : Autodesk Maya
flamtastic
on Aug 2, 2006 at 7:59:42 pm
Learning Maya 6 Foundation - Lesson 13 - page 240.
Mapping specularity within the Attribute Editor, how do I connect a node to a image file?
Pyro
Re: How to Connect Node to Image File?
by
on Aug 3, 2006 at 7:33:09 pm
Click the checkerbox next to the Specular attribute in the Attribute Editor. Then select the fileNode from the dialog that appears. Use "Normal" not "As Projection".
Now you should see the fileNode in the Hypershade.
