maya raytrace - nasty dotted shadow artifacts
COW Forums : Autodesk Maya
crackcode
on Jul 27, 2006 at 12:58:59 am
i use raytrace shadow for lights, maya SF for render with 3d motion bloor Q prset, and ryatracing enabled. shadows appears nasty dotted like dislve in PS. any idea how can improve this?
wheni use mentalray: 1)its slow 2) it gives nasty line artifacts for bent images.
any idea, thanks.
Steve Sayer
Re: maya raytrace - nasty dotted shadow artifacts
on Jul 29, 2006 at 2:33:12 pm
It sounds like you need to increase the number of Shadow Rays for that light. Try increasing that value in small increments until you find the results you're looking for.
Note that this is separate from the Render Globals quality settings, so if you've cranked those way up, you should turn them back down to the minimum acceptable levels.
-Steve
