Can't render an emitter particle
COW Forums : Autodesk Maya
JLK aniPNG
on Jul 19, 2006 at 7:30:23 am
I have just finished animating my emitter partcles but it can't render it.
What is the problem?
Please help.
Chad Briggs
Re: Can't render an emitter particle
on Jul 19, 2006 at 2:37:54 pm
what type of particle is it? If it's a hardware based particle, your only going to be able to use the hardware render buffer or hardware render module to render it out.
-chad
JLK aniPNG
on Jul 20, 2006 at 5:46:15 am
Its a streak particle......thnaks. One more question.!! : How do I change the particle type to photoshop image?
Steve Sayer
on Jul 20, 2006 at 8:12:43 pm
The particle type attribute is in the particleShape node. By the sound of it, you want the 'sprite' image type, to which you can assign an image or a series of images. Note that sprites, like streaks, are a hardware-rendered particle type. You will need to use Maya's Hardware Renderer to render them, and then composite them with any software-rendered elements to achive your final image.
-Steve
