image plane doesnt animate
COW Forums : Autodesk Maya
crackcode
on Jul 16, 2006 at 8:16:45 am
im using tga sequence (tried to use qt, avi, etc). i gues the problem is naming (numbering) convention or something.
i have "use image sequence" checked and related expression "=frame" is created.
what im doing wrong?
thnx
Chad Briggs
Re: image plane doesnt animate
on Jul 16, 2006 at 3:03:53 pm
first, make sure your sequence is named something like myfile.0001.tga. It is very finicky about the sequnce name. (i think you can also use myfile.0000)
Second, by default when you turn on the image sequence feature, it corresponds the frame # to the image sequence #. (so frame 23 plays back frame 23 of your animation). You can break the connections on this by right clicking and then you can keyframe it manually, or write your own image sequence expression.
-chad
crackcode
on Jul 16, 2006 at 4:51:47 pm
thanks Chad. i realy made mistake with naming files - i used file version numbers so maya didnt like any other numbers except frame numbers in file name.
kind regards.
