AVI playback problem
COW Forums : Autodesk Maya
on Jul 13, 2006 at 5:32:04 pm
I rendered out about 2 minutes of animation from Maya as an AVI file. Took it into IDVD and set it up to play automatically and continuously loop. When I previewed the animation it looked fine but when I took it to be played on the DVD player (for projection) there were groups of pizels that would stall. It looked kind of like a mosaic pattern that would every once in a while disturb the animation.
PS. The animation also looked fine played back on my PC. Any thoughts as to why I'm getting this pixelation like effect?
Re: AVI playback problem
on Jul 14, 2006 at 4:38:32 pm
I imagine it's some kind of glitch in the transcoding. I had a similar problem once going between premiere and after effects (strangely enough). It only did it with a specific combination of settings that I can't even remember... I think it happened because at the time I was using a current version of AE but an outdated version premiere that may have used a slightly different type of DV compression.
It might also be a problem with the video codecs on your machine.
It might also be your DVD player. Did the problem occur on 2 different players? What's the brand?
I don't think it's the disc or the burnprocess.
My advice would be to try a slightly different method. For example, I batch render JPGs frim Maya and import them into After Effects as an image sequence. There are countless other possibilities. These types of problems tend to be undocumented and difficult to replicate, so your best bet is to simply go around it.
GL -j
© 2018 All Rights Reserved
