smoothing illustrator paths in Maya
COW Forums : Autodesk Maya
wildstar
on Jun 5, 2006 at 6:15:30 pm
I've been bringing in Illustrator files into Maya, and the circles are all blocky. Does any one have an idea of how to bring the paths in so that they are perfectly smooth?
thx
ws
Chad Briggs
Re: smoothing illustrator paths in Maya
on Jun 5, 2006 at 7:32:34 pm
have you tried selecting the curve and hitting the 3 key? To see if it's just blocky in the viewport?
wildstar
on Jun 5, 2006 at 7:49:23 pm
it renders blocky too. i figured the circle would be imported like a nurb, but instead it looks low-poly
Chad Briggs
on Jun 5, 2006 at 8:46:26 pm
Hmm, i'm not in front of maya right now, but i think there are options for the curve import that might tell it whether to bring it in as nurbs, polys, etc. try checking that out.
-chad
wildstar
on Jun 5, 2006 at 10:25:21 pm
i take it back the #3 key did smooth out the curve and then i was able to boast the spans in the bevel options
Jon W.
on Jun 6, 2006 at 2:06:30 am
I've found the best way to rebuild Illustrator paths (for text or logos or whatever) that look blocky is to select path, go under Modeling module, Edit Curves/Insert Knots/change to Between Selects and adjust # Knots to taste. That way the corners and general appearance of your path remains the same but it adds additinal Knots to smooth out curves. No idea why Maya resorts to such bad approximations of Illustrator paths...
mYthprod
on Jun 6, 2006 at 2:06:00 pm
Good tip, thanks Jon!
- MythProd
(John David Hutton)
Build Your Own VelocityQ. See how:
http://www.customflix.com/Store/ShowTtl.jsp?id=205835
_______________________________________
Supermicro X5DA8, Dual Xeon 3.0 GHz
Windows XP Pro, SP1
VelocityQ, Version 9.1.41, Quattrus 140
VelocityX, Version 1.0.01
Kansas City, Kansas - United States
