disappearing floor textures...
COW Forums : Autodesk Maya
William Hamilton
on Jun 4, 2006 at 10:40:33 pm
Greetings,
I'm currently working on scene from a tutorial where I have some boxes and wires scattered around a room (room is simply the inside of a polygonal cube with a texture applied), but am having a problem with the room texture dissapearing. The tutorial I'm following had these steps for the room model
-Create a polygonal cube (width 25, height 10, depth 25, subdivisions 1/1/1
-under modeling menu set select, edit polygons/normals/reverse followed by display/component display/backfaces (to see the inside of the cube more clearly)
-apply room texture
-selected one face of the interior of the cube and did a number of extrudes
-a separate face (the floor) is now having trouble displaying the room texture as a result
What's weird about it is that when I rotate the camera at certain angles I can see the texture, but even a slight change will cause it to disapear. This problem started happening directly after I extruded one of the faces to create the window shown in the screenshots below.
normal
http://www.geocities.com/bannysvideo/mayawoes/Issue1.jpg
half broken
http://www.geocities.com/bannysvideo/mayawoes/Issue2.jpg
completely broken
http://www.geocities.com/bannysvideo/mayawoes/Issue3.jpg
Has this happened to anyone before? Just wondering if anyone has experienced this and knows what may be causing it. Any help or advice is greatly appreciated
Thanks again!
-William
Chad Briggs
Re: disappearing floor textures...
on Jun 5, 2006 at 12:06:11 am
One thing i would try is selecting the floor faces and doing a planar projection on the Y axis. When you do poly modelling on a object, it can sometiems cause the UV's to do wonky things.
-chad
William Hamilton
on Jun 16, 2006 at 7:10:34 am
Doing the planer projection on the Y axis wasn't able to fix the problem, but it did take care of some other issues I was having. Thanks a ton for the suggestion even if it ended up fixing something else :) For now though I think I'm going to put it aside until I get a little better at Maya, having a blast working on texturing anyhow
-William
