mental ray render iff file output cannot be imported into after effects
COW Forums : Autodesk Maya
bolzinski
on May 31, 2006 at 1:02:24 am
Hello,
Importing Maya 7.0 iff files into After Effects 7.0 causes an After Effects error message similar to, "Photoshop bad file format". The iff files are generated from a mental ray render.
Does anyone have information as to what causes this error and if it's going to be fixed anytime soon?
A workaround is to use FCheck to open the File Sequence and "re-save" as iff files. These files are then imported into AE 7.0 without error, but this is an extra step to our workflow that should not be necessary.
Thanks in advance for any help!
-Brian
Chad Briggs
Re: mental ray render iff file output cannot be imported into after effects
on May 31, 2006 at 1:49:47 am
I've been told there is a patch for this on alias... uh... autodesk.com :)
I haven't tried it, i just switched to using SGI sequences and that seems to work fine and retain a lot of the benifits of IFF.
Chad
