monitor render time?
COW Forums : Autodesk Maya
crackcode
on May 29, 2006 at 11:03:18 am
hi again!
is there any way to monitor rendering time in maya?
thnx
Chad Briggs
Re: monitor render time?
on May 29, 2006 at 2:00:10 pm
look at the render log file, it tells you how long each frame takes to render.
chad
crackcode
on May 29, 2006 at 2:05:59 pm
i have still frame to render it toook 20 or somthing hours. so i dont know to shout it down or wait some week more :(. as i remember (4 years ago) max had this progress bar? but i cant find it there.
Steve Sayer
on May 29, 2006 at 11:45:57 pm
If you're rendering from within Maya, it gives you a progress report... of course rendering from within Maya is not a good idea, especially with a 20 hour (!) render.
One thing you can do is use fcheck to open up your output file and just see how far along it is! Doing this doesn't disturb the render (equivalent to 'Show Batch Render' command in Maya).
-Steve
Steve Sayer
on May 29, 2006 at 11:49:33 pm
Also... does the 'verbose' batch render flag output a progress report? Anyone know?
-Steve
crackcode
on May 30, 2006 at 9:17:21 am
so, where would you sugest me to render 20 h project?
thanks for your seugestions.
Steve Sayer
on May 30, 2006 at 3:01:04 pm
You should render it using the batch renderer at a command prompt, i.e. not starting the render from within the Maya GUI. Is that what you're doing already? Or are you rendering by selecting 'Batch Render' from the Render menu within Maya?
-Steve
