maya using just 1.5GB RAM :(
COW Forums : Autodesk Maya
crackcode
on May 29, 2006 at 9:34:30 am
hi there!
im running render boxx with 3 gig of ram. in rendering by using just 1.5gig maya says "low memory".
so, the question is - how can i dirve maya to use rest of the memory?
thanks
Chad Briggs
Re: maya using just 1.5GB RAM :(
on May 29, 2006 at 1:59:26 pm
First off, that sounds like a really big render, i'm wondering if you've got something in your scene that causing a memory leak or something. I'd make sure your scene is optimized.
By defautl, 32bit windows can only allocate 2gb of ram per app. There is a switch that lets you allocate up to 3gb, but they reccomend you have 4gb of memory for this
http://www.microsoft.com/whdc/system/platform/server/PAE/PAEmem.mspx
The only other way to get more memory for an app is to run a 64bit OS, but even then you need a 64bit app, which maya is not (yet).
chad
crackcode
on May 29, 2006 at 2:11:31 pm
thanx you your replay!
actually i have 4gb. but system shows up just 3gb.
som maybe there is this switch
by the way i found in maya 6 documentation, that may dosnt suport more them 1.6gb. shit.
ill check it out your link.
and probaly i must learn something about optimization. im new in 3d.
is there some material online? can you recomed some book
thnx
Chad Briggs
on May 29, 2006 at 4:22:50 pm
optimization depends a lot on the scene at hand. can you post a sample render so i can see whats going on in the scene?
chad
crackcode
on May 29, 2006 at 4:48:07 pm
its like this x20 more. as well id like to add displacement.
http://www.apsits.com/client/screenShot_neir.jpg
thanks for your help!
Chad Briggs
on May 29, 2006 at 7:07:27 pm
Hmm, doesn't look that bad. Is it nurbs? Make sure your tesselation settings aren't going through the roof.
Another approcah would be to render the scene in passes, like redering out fg, bg, and mid objects so that you don't have to have all of them loadeded at the same time.
what kind of shader are you using? that can play a role as well.
