movie into a plane
COW Forums : Autodesk Maya
movie into a plane
on May 26, 2006 at 12:50:01 pm
I am writting to ask for help to all you maya experts out there.. :=)
I am trying to put a movie into a plane.
When I check on use image sequence Maya warns that the image does not exists and the image does not show at the preview or renders.
I am sure this is an easy one for somebody out there.
Re: movie into a plane
on May 26, 2006 at 4:01:38 pm
By default maya now assigns a simple expression to match the image sequence number to that frame. If you scrub your timeline higher than the number of frames you have in your image sequence, you'll get that message. You can delete the expression and write your own or keyframe if you want it to behave differently. If you're going to be going higher than your maximum number of image sequence frames I'd keyframe the last still to hold as I've had it black out on me in my renders (the last image sequence might've been a black still, I don't remember now).
- mYthprod
(John David Hutton)
* Build Your Own Velocity Q or HD. See how * :
Supermicro X5DA8, Dual Xeon 3.0 GHz
Windows XP Pro, SP1
VelocityQ, Version 9.1.39, Quattrus 140
© 2018 All Rights Reserved
