Distributing polys long a path
COW Forums : Autodesk Maya
cwise73
on May 24, 2006 at 5:29:14 pm
I am trying to distribute 50 poly objects evenly along a path, but I am having a hard time finding out how to do this. Any suggestions. Thanks!!
Steve Sayer
Re: Distributing polys long a path
on May 25, 2006 at 2:19:01 am
Is this for the razor wire?
In addition to my other suggestions, distributing polys could be accomplished like this:
1. Use path animation to animate the poly object along the path for 50 frames.
2. Use 'create animation snapshot' to duplicate the poly once per frame; this will give you the 50 copies.
Hope that's useful.
-Steve
