Detach surfaces not working as expected
COW Forums : Autodesk Maya
tomkarl
on Apr 7, 2006 at 5:17:32 pm
I'm new to this tool, going through Learning 7 Modeling & animation Handbook.
NURBS tutorial shows that you should be able to split a half sphere along 4 isoparms to get 6 adjacent surfaces. The tutorial, it's demo movie and Maya help show that you should be able to just delete a surface to create an open space.
The result I get is 6 overlaping pieces that are duplicates of the sphere cut along each isoparm and the original sphere is left behind - 2 vertical cut half spheres, a center piece cut vertically, a horizontal piece, 2 horizontal cut half spheres and the original half sphere. I've turned off keep original and saved the setting.
If you'd like to see a screen shot send me your email - tomkarl@cox.net
I'm using Maya Personal learning edition 7.01 upgraded from 7.0 when I started having this problem.
OS is XP Professional 64x, service pack 1.
Thanks in advance.
tomkarl
Re: Detach surfaces not working as expected
on Apr 12, 2006 at 10:48:50 pm
Ok, it was user error, to get the expected result you only detach one isoparm at a time.
