Is "Merge Vertices" broken in Maya 7.0.1? Or am I just using it wrong?
COW Forums : Autodesk Maya
switchcase
on Apr 6, 2006 at 10:43:49 pm
I'm having a lot of trouble getting merge vertices to work in Maya 7.0.1. Today I was trying to connect two matching cylindrical poly objects (one was a duplicate of the other) using merge vertices. No matter what the distance setting, the merger only produced 48 (the original number of polys), 32 or 2 polygons. I finally got it working by combining the object via Polygons > Combine, and then doing the merge vertices. Is that the correct way of getting merge vertices to work, or am I just dealing with an annoying bug?
Jason Brummett
Re: Is "Merge Vertices" broken in Maya 7.0.1? Or am I just using it wrong?
on Apr 7, 2006 at 2:03:15 am
You can't merge vertices of poly objects that aren't combined~1object or shape node.
Jason Brummett
Studio Z Inc.
