Animating opacity/ transparency (or alpha channel)
COW Forums : Autodesk Maya
Artpark
on Apr 3, 2006 at 1:58:18 am
I'm trying to animate an object to be slowly appear.
I was thinking more like fade in. I don't know if I can do it in Maya.
Animating opacity could be the answer.. I'm not sure.
How can I do that?
Chad Briggs
Re: Animating opacity/ transparency (or alpha channel)
on Apr 3, 2006 at 4:04:50 am
You'll need to put a shader on it, and animate the opacity of the shader. Look at the transparency attribute.
chad
Artpark
on Apr 3, 2006 at 5:01:04 pm
I actually found out that I need to do right click on transparency in Attribute and choose the Set key.
