Help.. Alpha appears to be premultiplied by white..
COW Forums : Autodesk Maya
anodecathode
on Apr 3, 2006 at 12:44:03 am
Working on an intro for a religious broadcast.. I have a tif sequence for the torso/head and a photoshop .psd for the legs and lower torso.. This is going to be a quick zoom out so it doesn't have to be a perfect composite, but the gray around the edges of the matte is noticeable even with a bit of motion blur. Does anyone know what is causing this?
http://img127.imageshack.us/my.php?image=forsunday3nograsshuh6oz.jpg
http://img111.imageshack.us/img111/5597/picture14ba.jpg
http://img104.imageshack.us/img104/2369/picture27gp.jpg
Jon W.
Re: Help.. Alpha appears to be premultiplied by white..
on Apr 3, 2006 at 8:02:31 am
You sure you're video layer of the guy is key'ed out cleanly? Thinking maybe you rendered it out as premultiplied alpha and Maya isn't interpreting it right. Try rendering out a straight alpha matte that's choked down and see if you still get the white ring, if so it's maya if not it's the source.
anodecathode
on Apr 4, 2006 at 3:17:27 am
Strangely enough.. I have noticed when I change the background color in photoshop.. (even though that layer is removed on save/export from photoshop) it effects the color of this distortion on the alpha edges.. The mask was created using the polygon tool and creating the alpha from the selection..
