Fluids and Paint Effects
COW Forums : Autodesk Maya
Matt Klundt
on Mar 31, 2006 at 4:43:23 pm
I have an animation of a fluid emitter creating a spray through a field of wheat created by using Paint Effects. My problem is that the Paint Effects render over the top of the rendered fluid and not smoothly within the created field (the spray is animated to be passing through the field).
Here is a test render with the problem.
Here is a test render without the Paint Effects.
Any suggestions on how I can render this correctly?
Jon W.
Re: Fluids and Paint Effects
on Apr 1, 2006 at 1:06:35 am
That's odd, i know paint effects is a post processes but was pretty sure it retained z-depth info. Well off the top of my head i would render them out in seperate passes and composite them in Shake of After Effects. Or you could also maybe convert the paint effects to polys but looking at your scene that might get really heavy.
© 2018 All Rights Reserved
